EDIT: andere kant
NOG EEN EDIT: En de spec's
ENGINE
Engine Type: Single cylinder, 4-stroke
Displacement (cc): 449.3
Bore x Stroke (mm): 97 / 60.8
Compression ratio: 12,5 : 1
Performance: approx. 59 HP
Starter: electric starter
Transmission: 4 gears
Carburetor: Keihin MX FCR 41
Control: 4V / DOHC with finger levers
Primary ratio: 29 : 74
Final drive: 5/8 x 1/4"
Cooling: Liquid cooled
Clutch: Wet multi-disc clutch, operated hydraulically
Ignition: Kokusan digital CDI
Frame: Chromium molybdenum
Subframe: Titanium
Handlebar: Aluminium
Front suspension: WP-USD 52 MA
Rear suspension: WP-PDS shock absorber
Suspension travel front/rear: 300 / 335 mm
Front brakes: Disc brake 260 mm
Rear brakes: Disc brake 220 mm
Front/rear rims: 1.6 x 21" / 2.15 x 19"
Front/rear tyres: 80/100-21" / 110/90-19"
Transmission ratio: 14:50
Main silencer: Titanium
Steering head angle: 63.5°
Wheel caster: 112 mm
Wheelbase: 1481±10 mm
Ground clearance (unloaded): 380mm
Seat height (unloaded): 925mm
Fuel capacity: approx. 7 liters
Weight: approx. 100 kg
